| Oracle® Communications EAGLE Commands Error Recovery Reference Release 46.6 E93312 Revision 1 |
![]() Previous |
![]() Next |
If a value of partial or default is specified for the type parameter, then the rcontext parameter must be specified.
Recovery
Re-enter the chg-appl-rtkey command that generated this error message, specifying a valid combination of parameters. Refer to the Commands User's Guide and to the Database Administration - IP7 User's Guide for assistance.
