Go to primary content
Oracle® Communications EAGLE Commands Error Recovery Reference
Release 46.6
E93312 Revision 1
Go To Table Of Contents
Contents
Previous
Previous
Next
Next
E4718 Cmd Rej: DefMCC can't be NONE if MT-Based GSM SMS NP feature is ON
If the MT-Based GSM SMS NP feature is turned on, then the defmcc=none parameter cannot be specified.
Recovery
  1. Display the status of the MT-Based GSM SMS NP feature. Enter the rtrv-ctrl-feat command.
    If the feature does not appear in the output, then the feature is not enabled. If the feature has a status of OFF, then the feature is enabled but is not turned on.
  2. Re-enter the chg-gsmopts command that generated this error message, specifying a valid combination of parameters. Refer to the command description in Commands User's Guide and to the G-Port User's Guide for assistance.
