Go to primary content
Oracle® Communications EAGLE Commands Error Recovery Reference
Release 46.6
E93312 Revision 1
Go To Table Of Contents
Contents
Previous
Previous
Next
Next
E4945 Cmd Rej: FPFX value cannot end with a '?'
The value specified for the fpfx parameter cannot contain a ? as the final character.
Recovery
Re-enter the ent-npp-srs command that generated this error message, specifying a valid combination of parameters. Refer to the command description in Commands User's Guide and to the Numbering Plan Processor (NPP) User's Guide for assistance.
Contact My Oracle Support if this error message appears again. See My Oracle Support (MOS).
