Go to primary content
Oracle® Communications EAGLE Commands Error Recovery Reference
Release 46.6
E93312 Revision 1
Go To Table Of Contents
Contents
Previous
Previous
Next
Next
E4208 Cmd Rej: No other parameters are permitted with the NEXT parameter.
If the next parameter is specified, then no other parameters can be specified.
Recovery
Re-enter the rtrv-log command that generated this error message, specifying a valid combination of parameters. Refer to the command description in Commands User's Guide for assistance.
