Go to primary content
Oracle® Communications EAGLE Commands Error Recovery Reference
Release 46.6
E93312 Revision 1
Go To Table Of Contents
Contents
Previous
Previous
Next
Next
E4408 Cmd Rej: OPCx parm must be specified if GTTSN is type of OPC
The opc/opca/opci/opcn/opcn24 parameter must be specified if the value specified for the GTTSN set type is opc. These parameters can only be specified if the GTTSN set type is opc.
Recovery
  1. Display the set types. Enter the rtrv-gttset command.
  2. Change the set type if desired. Refer to the Database Administration - GTT User's Guide for assistance.
  3. Re-enter the ent/chg/dlt-gta command that generated this error message.
    Contact My Oracle Support if this error message appears again. See My Oracle Support (MOS).
