Go to primary content
Oracle® Communications EAGLE Commands Error Recovery Reference
Release 46.6
E93312 Revision 1
Go To Table Of Contents
Contents
Previous
Previous
Next
Next
E4189 Cmd Rej: Invalid PC type for the subsystem associated with SSN value
If a subsystem is configured for a subsystem number (SSN) value in the SS-APPL table, then the specified MAP table entry for that subsystem must be a valid point code type for that subsystem. The following point code types are not valid for the indicated subsystems:
  • For the INP subsystem, the True Point code cannot be an ITU-I point code.
  • For the AIQ, ATINPQ, VFLEX, or EIR subsystem, the True Point code can not be an ITU-N24 point code.
Recovery
  1. Display the entries in the SS-APPL table. Enter the rtrv-ss-appl command.
  2. Re-enter the ent/chg-map command that generated this error message, specifying a valid combination of parameters. Refer to the command description in Commands User's Guide and to Database Administration - GTT User's Guide for assistance.
    If this error message appears again, contact My Oracle Support. See My Oracle Support (MOS).
