| Oracle® Communications EAGLE Commands Error Recovery Reference Release 46.6 E93312 Revision 1 |
![]() Previous |
![]() Next |
The alias parameter must be specified with a different point code type than the dpc parameter. A specified alias type cannot already be defined as a destination address.
The aliasa and dpca parameters cannot be specified together in the command. The aliasi and dpci parameters and the aliasn and dpcn parameters cannot be specified together in the command if the prefix subfields are the same (both are spare or both are non-spare).
Recovery
