Go to primary content
Oracle® Communications EAGLE Commands Error Recovery Reference
Release 46.6
E93312 Revision 1
Go To Table Of Contents
Contents
Previous
Previous
Next
Next
E2893 Cmd Rej: REP must be greater than prev. and less than subsequent REP
The rep parameter value that is specified for this loopback point (LBP) must be greater than the rep parameter value of any previously defined LBP and less than the rep parameter value of any subsequently defined LBP.
Recovery
  1. Display all the loopback points on the signaling links for this STP. Enter the rtrv-lbp command.
    The loopback point IDs for each signaling link are displayed in numerical order in the LBP field. The RLEs for each LBP are listed in the RLE field, and the repetition counts for the LBPs are listed in the REP field of the output.
  2. Re-enter the ent/chg-lbp command that generated this error message, specifying a valid combination of parameters. Refer to the command description in Commands User's Guide and to the Database Administration - SS7 User's Guide for assistance.
