| Oracle® Communications EAGLE Commands Error Recovery Reference Release 46.6 E93312 Revision 1 |
![]() Previous |
![]() Next |
For the ent/chg-e1 commands, HIPR2 cards must be equipped in card locations xy09 and xy10 on each shelf that contains one or more HC-MIM or E5-E1T1 cards that are used as E1 or SE-HSL cards.
For the ent-slk command, HIPR2 cards must be in card locations xy09 and xy10 on each shelf that contains one or more HC-MIM, E5-E1T1, E5-E1T1-B, E5-ENET, E5-ENET-B, or SLIC cards when link parameter values a4-a63 and b4-b63 are specified.
For the ent/chg-t1 commands, HIPR2 cards must be equipped in card locations xy09 and xy10 on each shelf that contains one or more HC-MIM or E5-E1T1 cards that are used as T1 cards or ST-HSL-A cards.
Recovery
