Go to primary content
Oracle® Communications EAGLE Commands Error Recovery Reference
Release 46.6
E93312 Revision 1
Go To Table Of Contents
Contents
Previous
Previous
Next
Next
E2924 Cmd Rej: LOC has maximum number of LFS Tests already in progress
The maximum number of allowed tests is already in progress on this LOC. At least one active LFS test on this LOC must be completed before another act-lbp command can be performed for this card location.
Recovery
  1. Determine the amount of time until test completion for the LOC. Enter the rept-stat-lfs command.
  2. Re-enter the act-lbp command that generated this error message after the test on the LOC completes.
    Contact My Oracle Support if this error message appears again. See My Oracle Support (MOS).
