| Oracle® Communications EAGLE Commands Error Recovery Reference Release 46.6 E93312 Revision 1 |
![]() Previous |
![]() Next |
The revoke=yes parameter cannot be specified for a user ID with system administration authorization.
Recovery
Re-enter the ent/chg-user command that generated this error message, specifying a valid combination of parameters. Refer to the command description in Commands User's Guide and to the Database Administration - System Management User's Guide for assistance.
Theent/chg-user commands can be entered only by a use wirth system administration authority.
