Go to primary content
Oracle® Communications EAGLE Commands Error Recovery Reference
Release 46.6
E93312 Revision 1
Go To Table Of Contents
Contents
Previous
Previous
Next
Next
E2608 Cmd Rej: IPADDR not assigned to a TCP/IP link
The IP address specified for the ipaddr parameter must be the IP address of a TCP/IP node instead of a TCP/IP data link.
Recovery
  1. Display the TCP/IP nodes in the database. Enter the rtrv-ip-node command.
  2. Re-enter the ent/dlt-ip-node command that generated this error message, specifying a valid combination of parameters. Refer to the command description in Commands User's Guide and to the Database Administration - Features User's Guide for assistance.
    Contact My Oracle Support if this error message appears again. See My Oracle Support (MOS).
