Go to primary content
Oracle® Communications EAGLE Commands Error Recovery Reference
Release 46.6
E93312 Revision 1
Go To Table Of Contents
Contents
Previous
Previous
Next
Next
E3792 Cmd Rej: Gtwy IPAddr must be local to any one of the n/w on the card
For the card in the location specified in the loc parameter, the gateway IP address must correspond to an IP address that is local to this card’s A or B a network on the card.
Recovery
  1. Display the existing IP routes. Enter the rtrv-ip-rte command.
  2. Display the information for the IP cards. Enter the rtrv-ip-card command.
  3. Re-enter the ent-ip-rte command that generated this error message, specifying a valid combination of parameters. Refer to the command description in Commands User's Guide and to the Database Administration - IP7 User's Guide for assistance.
    Contact My Oracle Support if this error message appears again. See My Oracle Support (MOS).
