Go to primary content
Oracle® Communications EAGLE Commands Error Recovery Reference
Release 46.6
E93312 Revision 1
Go To Table Of Contents
Contents
Previous
Previous
Next
Next
E5336 Cmd Rej: SA BLNFNDRLS SA(X)VAL values must be between 0-127
If the Action Set specified by the asn parameter contains the BLNFNDRLS Service Action, then the 2 numerical values specified by the numerical values list must each be between 0-127.
Recovery
  1. Display the Service Action entries in the Action Set. Enter the rtrv-npp-as:mode=full command.
  2. Revise the Service Action entries as necessary. Refer to the Numbering Plan Procssor (NPP) Overview and to the appropriate feature manual for assistance.
  3. Re-enter the ent/chg-npp-srs command that generated this error message, specifying a valid combination of parameters. Refer to the command description in Commands User's Guide for assistance.
    Contact My Oracle Support if this error message appears again. See My Oracle Support (MOS).
