Go to primary content
Oracle® Communications EAGLE Commands Error Recovery Reference
Release 46.6
E93312 Revision 1
Go To Table Of Contents
Contents
Previous
Previous
Next
Next
E2616 Cmd Rej: IPADDR w/o IPRTE must match first 3 octets of TCP/IP link
The value specified for the network portion of the ipaddr parameter must match the network portion of the IP address assigned to the TCP/IP data link.
The network portion of the IP address is based on the class of the IP address. If the IP address is a Class A IP address, the first field is the network portion of the IP address. If the IP address is a Class B IP address, the first two fields are the network portion of the IP address. If the IP address is a Class C IP address, the first three fields are the network portion of the IP address.
Recovery
  1. Display the IP addresses of the TCP/IP data links. Enter the rtrv-dlk command.
  2. Display the IP addresses of the TCP/IP nodes. Enter the rtrv-ip-node command.
  3. Re-enter the ent-ip-node command that generated this error message, specifying a valid combination of parameters. Refer to the command description in Commands User's Guide and to the Database Administration - Features User's Guide for assistance.
    Contact My Oracle Support if this error message appears again. See My Oracle Support (MOS).
