| Oracle® Communications EAGLE Commands Error Recovery Reference Release 46.6 E93312 Revision 1 |
![]() Previous |
![]() Next |
The Measurements Platform feature must be turned on before the ent-card command can be entered for a type MCPM card (E5-MCPM-B).
For the chg-measopts command, the Measurements Platform feature must be turned on before the platformenable=on parameter can be specified.
Once a feature that is controlled using a feature bit has been turned on, it cannot be turned off.Recovery
