Go to primary content
Oracle® Communications EAGLE Commands Error Recovery Reference
Release 46.6
E93312 Revision 1
Go To Table Of Contents
Contents
Previous
Previous
Next
Next
E3795 Cmd Rej: LNP ported NPANXXs 300K Qty Feat Requires at least DSM2GB
At least a 2 GB DSM card must be installed before the LNP ported NPANXX 300K Quantity Key feature can be enabled.
Recovery
  1. Display the cards in the system. Enter the rtrv-card and rtrv-stp commands.
  2. Upgrade the hardware as necessary. Refer to the Maintenance Guide for assistance.
  3. Re-enter the enable-ctrl-feat command that generated this error essage.
    Contact My Oracle Support if this error message appears again. See My Oracle Support (MOS).
