Go to primary content
Oracle® Communications EAGLE Commands Error Recovery Reference
Release 46.6
E93312 Revision 1
Go To Table Of Contents
Contents
Previous
Previous
Next
Next
E3171 Cmd Rej: TS value on the J1 already in use by a signaling link
A specific time slot can be assigned in the ts parameter to only one J1 signaling link for the J1 interface that services that time slot.
Recovery
  1. Use the rtrv-j1 command with the loc and j1port parameters to see the time slots that have already been assigned.
  2. Re-enter the ent-slk command on a particular port with a ts parameter value that is not already used for any link (slk) on that particular port.
    If this error message appears again, contact My Oracle Support. See My Oracle Support (MOS).
