Go to primary content
Oracle® Communications EAGLE Commands Error Recovery Reference
Release 46.6
E93312 Revision 1
Go To Table Of Contents
Contents
Previous
Previous
Next
Next
E3532 Cmd Rej: Exceeding max number of SS7 links for GTT-enabled IPSG card
The card has exceeded the maximum of 32 links configured on a GTT-enabled IPSG card.
Recovery
If trying to change an NOSCCP IPSG card with more than 32 equippped links to a GTT-enabled IPSG card:
  1. Remove SLKs until the number of SLKs on the NOSCCP IPSG card is less than or equal to 32.
  2. Retry changing the card from NOSCCP to GTT-enabled IPSG card.
