| Oracle® Communications EAGLE Commands Error Recovery Reference Release 46.6 E93312 Revision 1 |
![]() Previous |
![]() Next |
The split, rc, ncics, or ncice parameter must be specified in the command.
Recovery
Re-enter the chg-appl-rtkey command that generated this error message, specifying a valid combination of parameters. Refer to the command description in Commands User's Guide and to the Database Administration - IP7 User's Guide for assistance.
Contact My Oracle Support if this error message appears again. See My Oracle Support (MOS).
