Go to primary content
Oracle® Communications EAGLE Commands Error Recovery Reference
Release 46.6
E93312 Revision 1
Go To Table Of Contents
Contents
Previous
Previous
Next
Next
E4185 Cmd Rej: EIR feature must be enabled
For the dlt-ss-appl command, the EIR feature must be enabled before the appl=eir parameter can be specified.
For the rtrv-sid command, the EIR feature must be enabled before the cpctype=eir parameter can be specified.
Recovery
  1. Display the status of the EIR feature. Enter the rtrv-ctrl-feat command.
    If the feature does not appear in the output, then the feature is not enabled. If the feature has a status of OFF, then the feature is enabled but is not turne don.
  2. Enable and turn on the EIR feature as necessary. Refer to the EIR User's Guide for assistance.
  3. Re-enter the command that generated this error message.
    Contact My Oracle Support if this error message appears again. See My Oracle Support (MOS).
