Go to primary content
Oracle® Communications EAGLE Commands Error Recovery Reference
Release 46.6
E93312 Revision 1
Go To Table Of Contents
Contents
Previous
Previous
Next
Next
E2988 Cmd Rej: Maximum number of Mated Applications (MAP) exceeded
A maximum of 128 mated applications is allowed per MAP set.
Recovery
  1. Display the existing MAP set information. Enter the rtrv-map command.
  2. Delete an existing mated application and re-enter the chg-map command that generated this error message, or re-enter the mated application as a primary point code. Refer to the command description in Commands User's Guide and to the Database Administration - GTT User's Guide for assistance.
    Contact My Oracle Support if this error message appears again. See My Oracle Support (MOS).
