Go to primary content
Oracle® Communications EAGLE Commands Error Recovery Reference
Release 46.6
E93312 Revision 1
Go To Table Of Contents
Contents
Previous
Previous
Next
Next
E4772 Cmd Rej: IPADDR and PORT combination cant be same for both the CCSMRs
The port and ipaddr parameters must have unique values for each CCS MR
Recovery
  1. Display the existing port and ipaddr parameter values. Enter the rtrv-seas-config command.
  2. Re-enter the chg-seas-config command that generated this error message, specifying a valid combination of parameters. Refer to the command description in Commands User's Guide and to the Database Administration - System Management User's Guide for assistance.
