Go to primary content
Oracle® Communications EAGLE Commands Error Recovery Reference
Release 46.6
E93312 Revision 1
Go To Table Of Contents
Contents
Previous
Previous
Next
Next
E2067 Cmd Rej: Card location specified must be an SIP card
For the rept-stat-sip command, the card location specified must be an SIP card.
For the rtrv-gttset command, duplicate values cannot be specified for the setidx parameter.
Recovery
  1. Enter the rtrv-card command to verify the card location is provisioned as a SIP card.
  2. Re-enter the command that generated this error message, specifying a valid combination of parameters. Refer to the command description in Commands User's Guide and Database Administration - Features User's Guide for assistance.
    Contact My Oracle Support if this error message appears again. See My Oracle Support (MOS).
