| Oracle® Communications EAGLE Commands Error Recovery Reference Release 46.6 E93312 Revision 1 |
![]() Previous |
![]() Next |
If the TOBR quantity feature of maximum quantity level is enabled, then no other TOBR Quantity feature can be enabled.
Recovery
Display the TOBR quantity present in the system. Enter the rtrv-ctrl-feat command.
If the maxiumum quantity is enabled, then no recovery is required.
Contact My Oracle Support for additional assistance. See My Oracle Support (MOS).
