Go to primary content
Oracle® Communications EAGLE Commands Error Recovery Reference
Release 46.6
E93312 Revision 1
Go To Table Of Contents
Contents
Previous
Previous
Next
Next
E5324 Cmd Rej: FAs ASDOTHER and GRNOTHER require INVKSERV not equal to NONE
If the Action Set specified by the asn parameter contains the ASDOTHER or GRNOTHER Formatting Action, then the invkserv=none parameter cannot be specified.
Recovery
  1. Display the Formatting Actions in the Action Set. Enter the rtrv-npp-as:asn= command.
  2. Revise the Formatting Actions as desired. Refer to the Numbering Plan Processor (NPP) User's Guide and to the appropriate feature manual for assistance.
  3. Re-enter the ent/chg-npp-srs command that generated this error message, specifying a valid combination of parameters. Refer to the command description in Commands User's Guide for assistance.
    Contact My Oracle Support if this error message appears again. See My Oracle Support (MOS).
