Go to primary content
Oracle® Communications EAGLE Commands Error Recovery Reference
Release 46.6
E93312 Revision 1
Go To Table Of Contents
Contents
Previous
Previous
Next
Next
E5188 Cmd Rej: Target bus must be IS-NR or IS-ANR
The target bus must be in an in-service normal (IS-NR) or in-service abnormal (IS-ANR) state before the tst-imt command can be entered for an Extended Bit Rate Error Test (BERT).
Recovery
  1. Display the state of the IMT buses. Enter the rept-stat-imt command.
    The state of the IMT bus is shown in the PST field of the rept-stat-imt command output.
  2. Place the target bus into an allowed state as necessary. Refer to the Maintenance Guide for assistance.
  3. Re-enter the tst-imt command that generated this error message, specifying a valid combination of parameters. Refer to the command description in Commands User's Guide for assistance.
    Contact My Oracle Support if this error message appears again. See My Oracle Support (MOS).
