Go to primary content
Oracle® Communications EAGLE Commands Error Recovery Reference
Release 46.6
E93312 Revision 1
Go To Table Of Contents
Contents
Previous
Previous
Next
Next
E3091 Cmd Rej: PC/SSN must be given with Action FORWARD, DUPLICATE, DUPDISC
If the command contains the dfltact, ndfltact, or (n)action parameter that is set to a value of forward, duplicate, or dupdisc, then the point code and subsystem number parameters must be specified in the command.
Recovery
  1. Display the current values for the parameters in the command. Enter the rtrv-gsmmap-scrn or rtrv-gsms-opcode command, as appropriate.
  2. Revise the data as necessary. Refer to the Database Administration - Features User's Guide for assistance.
  3. Re-enter the ent/chg-gsmmap-scrn or ent/chg-gsms-opcode command that generated this error message, specifying a valid combination of parameters. Refer to the command description in Commands User's Guide and to the Database Administration - Features User's Guide for assistance.
    Contact My Oracle Support if this error message appears again. See My Oracle Support (MOS).
