| Oracle® Communications EAGLE Commands Error Recovery Reference Release 46.6 E93312 Revision 1 |
![]() Previous |
![]() Next |
A valid value must be specified for the oa parameter.
Recovery
Re-enter the send-msg command that generated this error message, specifying a valid combination of parameters. Refer to the command description in the Commands User's Guide for assistance.
Contact My Oracle Support if this error message appears again. See My Oracle Support (MOS).
