Go to primary content
Oracle® Communications EAGLE Commands Error Recovery Reference
Release 46.6
E93312 Revision 1
Go To Table Of Contents
Contents
Previous
Previous
Next
Next
E3906 Cmd Rej: The GSM Map Screening table is full
The GSM MAP Screening table can contain a maximum of 4000 entries.
Recovery
  1. Display the current entries in the GSM MAP Screening table. Enter the rtrv-gsmmap-scrn command.
  2. Delete MAP Screening entries as necessary. Refer to the Database Administration - Features User's Guide for assistance.
  3. Re-enter the ent-gsmmap-scrn command that generated this error message.
    Contact My Oracle Support if this error message appears again. See My Oracle Support (MOS).
