Go to primary content
Oracle® Communications EAGLE Commands Error Recovery Reference
Release 46.6
E93312 Revision 1
Go To Table Of Contents
Contents
Previous
Previous
Next
Next
E3515 Cmd Rej: CCNC already exists
The value specified for the ccnc parameter cannot already exist unless the mccmnc=none parameter is also specified.
Recovery
Re-enter the chg-gsmopts command that generated this error message.
  1. Display the existing values for the ccnc and mccmnc parameters. Enter the rtrv-gsmopts command.
  2. Re-enter the chg-gsmopts command that generated this error message, specifying a valid combination of parameters. Refer to the command description in Commands User's Guide for assistance.
    Contact My Oracle Support if this error message appears again. See My Oracle Support (MOS).
