Go to primary content
Oracle® Communications EAGLE Commands Error Recovery Reference
Release 46.6
E93312 Revision 1
Go To Table Of Contents
Contents
Previous
Previous
Next
Next
E4292 Cmd Rej: SADDR must be specified when EGMS feature is OFF
If the Enhanced GSM MAP Screening (EGMS) feature is turned off, then the saddr parameter must be specified.
Recovery
  1. Display the status of the EGMS feature. Enter the rtrv-ctrl-feat command.
    If the feature does not appear in the output, then the feature is not enabled. If the feature has a status of OFF, then the feature is enabled but is not turned on.
  2. Turn on the EGMS feature, if desired. Refer to the Database Administration - Features User's Guide for assistance.
  3. Re-enter the ent-gsmmap-scrn command that generated this error message, specifying a valid combination of parameters. Refer to the command description in Commands User's Guide and to the Database Administration - Features User's Guide for assistance.
    Contact My Oracle Support if this error message appears again. See My Oracle Support (MOS).
