Go to primary content
Oracle® Communications EAGLE Commands Error Recovery Reference
Release 46.6
E93312 Revision 1
Go To Table Of Contents
Contents
Previous
Previous
Next
Next
E4608 Cmd Rej: True Point Code can exist only in Default MAPSET
A true PC/SSN can only exist in the default MAP Set.
Recovery
  1. Display the site point codes in the EAGLE. Enter the rtrv-sid command.
    The site point codes are shown in the PCA, PCI, PCN, and PCN24 fields of the rtrv-sid command output.
  2. Re-enter the ent/chg-map command that generated this error message, specifying a valid combination of parameters. Refer to the command description in Commands User's Guide and to Database Administration - GTT User's Guide for assistance.
    Contact My Oracle Support if this error message appears again. See My Oracle Support (MOS).
