Go to primary content
Oracle® Communications EAGLE Commands Error Recovery Reference
Release 46.6
E93312 Revision 1
Go To Table Of Contents
Contents
Previous
Previous
Next
Next
E2847 Cmd Rej: IF IO or ETT specified, BOTH opt. parms must be specified
The io and ett parameters must be specified together in the command.
Recovery
Re-enter the dlt-ttmap command that generated this error message, specifying a valid combination of parameters. Refer to the command description in the Commands User's Guide and to the Database Administration - GTT User's Guide for assistance.
Contact My Oracle Support if this error message appears again. See My Oracle Support (MOS).
