| Oracle® Communications EAGLE Commands Error Recovery Reference Release 46.6 E93312 Revision 1 |
![]() Previous |
![]() Next |
The value specified for the enum parameter must be in the same range as the value specified for the snum parameter. Refer to the command description in Commands User's Guide for the valid ranges.
Recovery
Re-enter the rtrv-log or rtrv-trbltx command that generated this error message, specifying a valid combination of parameters.
