Go to primary content
Oracle® Communications EAGLE Commands Error Recovery Reference
Release 46.6
E93312 Revision 1
Go To Table Of Contents
Contents
Previous
Previous
Next
Next
E4490 Cmd Rej: Card type must be DCM/SLIC for a 100Mbit link
If the speed=100 parameter is specified, then the card in the specified location must be an E5-ENET or E5-ENET-B card running the SLANHC GPL. For both cards, the card type in the ent-card command is DCM.
Recovery
  1. Display the card information. Enter the rtrv-card command and rtrv-stp commands.
  2. Replace the cards as necessary. Refer to Maintenance Guide for assistance.
  3. Re-enter the ent-dlk command that generated this error message, specifying a valid combination of parameters. Refer to the command description in Commands User's Guide and to Database Administration - Features User's Guide for assistance.
    Contact My Oracle Support if this error message appears again. See My Oracle Support (MOS).
