Go to primary content
Oracle® Communications EAGLE Commands Error Recovery Reference
Release 46.6
E93312 Revision 1
Go To Table Of Contents
Contents
Previous
Previous
Next
Next
E3392 Cmd Rej: ESWT, GRPWT and THR can't be specified for SOL or DOM groups
The eswt, grpwt, and thr parameters cannot be specified if the MAP group or MRN group is in solitary or dominant mode.
Recovery
  1. Determine the mode of the MAP group or MRN group. Enter the rtrv-map or rtrv-mrn command, respectively.
    In solitary mode, the PC/SSN is not replicated. In dominant mode, each PC/SSN has a unique relative cost.
  2. Revise the settings for the MAP or MRN group if desired. Refer to the Database Administration - GTT User's Guide for assistance.
  3. Re-enter the chg-map or chg-mrn command that generated this error message, specifying a valid combination of parameters. Refer to the command description in Commands User's Guide for assistance.
    Contact My Oracle Support if this error message appears again. See My Oracle Support (MOS).
