Go to primary content
Oracle® Communications EAGLE Commands Error Recovery Reference
Release 46.6
E93312 Revision 1
Go To Table Of Contents
Contents
Previous
Previous
Next
Next
E2673 Cmd Rej: Default Phone Context cannot be deleted
For the dlt-sip-npp command, the Default Phone Context cannot be deleted from the SIPPHCXT table.
Recovery
  1. Enter the rtrv-sip-npp command to display the outputs of the SIPPHCXT parameter specified in the system.
  2. Enter the dlt-sip-npp command to delete any rules with the Default Phone Context specified.
  3. Re-enter the command that generated this error message, specifying a valid combination of parameters. Refer to the command description in the Commands User's Guide and Database Administration - Features User's Guide for assistance.
    Contact My Oracle Support if this error message appears again. See My Oracle Support (MOS).
