Go to primary content
Oracle® Communications EAGLE Commands Error Recovery Reference
Release 46.6
E93312 Revision 1
Go To Table Of Contents
Contents
Previous
Previous
Next
Next
E2180 Cmd Rej: Current stdby OAM db is not supported for this upgrade
The database on the standby TDM is not at the proper level for this command.
Caution:
It is strongly recommended that this command be used only in conjunction with the system Upgrade Procedure for the target release. The Upgrade Procedure provides step-by-step information on performing an upgrade.
Recovery
Enter the act-upgrade:action=dbstatus command to verify the version of the database on the standby TDM. The version of the database is shown in the VERSION STATUS field.
Contact My Oracle Support for additional assistance. See My Oracle Support (MOS).
