Go to primary content
Oracle® Communications EAGLE Commands Error Recovery Reference
Release 46.6
E93312 Revision 1
Go To Table Of Contents
Contents
Previous
Previous
Next
Next
E2493 Cmd Rej: H1 must be wild card if H0 is wild card
If a wild-card (*) value is specified for the h0 parameter, then a wild-card value must be specified for the h1 parameter.
A ‘wild card’ is used to describe the asterisk parameter value ‘*’ that indicates the full range of values. Do not confuse this usage with the parameter value '**', which SEAS uses for “all and every entry in the database including the value '*'”.
Recovery
Re-enter the command that generated this error message, specifying a valid combination of parameters. Refer to the command description in Commands User's Guide for assistance.
Contact My Oracle Support if this error message appears again. See My Oracle Support (MOS).
