| Oracle® Communications EAGLE Commands Error Recovery Reference Release 46.6 E93312 Revision 1 |
![]() Previous |
![]() Next |
If the eswt, grpwt, or thr parameter is specified, then the mrnpc parameter cannot be specified.
Recovery
Re-enter the chg-map command that generated this error message, specifying a valid combination of parameters. Refer to the command description in Commands User's Guide and to the Database Administration - GTT User's Guide for assistance.
