Go to primary content
Oracle® Communications EAGLE Commands Error Recovery Reference
Release 46.6
E93312 Revision 1
Go To Table Of Contents
Contents
Previous
Previous
Next
Next
E4847 Cmd Rej: SAPC is prohibited on IPSG-M3UA linksets
If the ipsg=yes and adapter=m3ua parameters are specified, a linkset cannot have an SAPC.
Recovery
  1. Display the linkset settings. Enter the rtrv-ls command.
  2. Revise the linkset settings as necessary. Refer to the Database Administration - IP7 User's Guide for assistance.
  3. Re-enter the chg-ls command that generated this error message.
    Contact My Oracle Support if this error message appears again. See My Oracle Support (MOS).
