Go to primary content
Oracle® Communications EAGLE Commands Error Recovery Reference
Release 46.6
E93312 Revision 1
Go To Table Of Contents
Contents
Previous
Previous
Next
Next
E4073 Cmd Rej: AS/socket cannot be deleted while assigned to a routing key
Any association between the application server (AS) and the routing key must be deleted before the AS association can be deleted.
Recovery
  1. Display the current AS and routing key associations. Enter the rtrv-appl-rtkey command.
  2. Delete the AS association with the routing key. Refer to the Database Administration - IP7 User's Guide for assistance.
  3. Re-enter the command that generated this error message.
    Contact My Oracle Support if this error message appears again. See My Oracle Support (MOS).
