Go to primary content
Oracle® Communications EAGLE Commands Error Recovery Reference
Release 46.6
E93312 Revision 1
Contents
Previous
Next
E2824 Cmd Rej: Could not access standby fixed disk
A hardware problem may exist.
Recovery
Dispaly the status of the standby TDM. Enter the
rept-stat-db
command.
If the status of the standby TDM shows
noaccs
, contact My Oracle Support. See
My Oracle Support (MOS)
stdby
, re-enter the
copy-fta
copy-gpl
, or
format-disk
command that generated this error message.
Caution:
Contact My Oracle Support before entering the
format-disk
command. See
