| Oracle® Communications EAGLE Commands Error Recovery Reference Release 46.6 E93312 Revision 1 |
![]() Previous |
![]() Next |
If the maximum quantity PCT feature is already enabled, then a PCT feature of lower quantity cannot be enabled.
Recovery
Display the status of of the PCT feature. Enter the rtrv-ctrl-feat command.
If the feature does not appear in the output then the feature is not enabled.
If the maximum quantity PCT feature is enabled, no further action can be taken.
Contact My Oracle Support if additional assistance is required. See My Oracle Support (MOS).
