Go to primary content
Oracle® Communications EAGLE Commands Error Recovery Reference
Release 46.6
E93312 Revision 1
Go To Table Of Contents
Contents
Previous
Previous
Next
Next
E3399 Cmd Rej: Association is not assigned to AS
The association specified by the aname parameter must be assigned to the application server specified by the asname parameter.
Recovery
  1. Display the associations assigned to the application server of interest. Enter the rtrv-as:asname= command, specifying the application server of interest.
  2. If desired, display the application server where the association is assigned. Enter the rtrv-assoc:aname= command, specifying that association of interest.
  3. Revise the assignments as desired. Refer to the Database Administration - IP7 User's Guide for assistance.
  4. Re-enter the rept-meas command that generated this error message, specifying a valid combination of parameters. Refer to the command description in Commands User's Guide and to the Measurements Reference for assistance.
    Contact My Oracle Support if this error message appears again. See My Oracle Support (MOS).
