Go to primary content
Oracle® Communications EAGLE Commands Error Recovery Reference
Release 46.6
E93312 Revision 1
Go To Table Of Contents
Contents
Previous
Previous
Next
Next
E2382 Cmd Rej: Only 4 ports with sys maint. output group ON are allowed
Only 4 terminals can be configured to receive system maintenance-related unsolicited messages.
Recovery
  1. Display the terminals configured to receive system maintenance-related unsolicited messages. Enter the rtrv-trm command.
    The SYS field should display YES for each of the four terminals so configured.
  2. Revise the data as necessary. Refer to the Database Administration - System Management User's Guide for assistance.
  3. Re-enter the chg-trm command that generated this error message.
    Contact My Oracle Support if this error message appears again. See My Oracle Support (MOS).
