Go to primary content
Oracle® Communications EAGLE Commands Error Recovery Reference
Release 46.6
E93312 Revision 1
Go To Table Of Contents
Contents
Previous
Previous
Next
Next
E2742 Cmd Rej: T1 is assigned to card
Before a T1 card can be deleted, any T1 interfaces assigned to the card must be deleted.
Recovery
  1. Display the list of signaling links assigned to the T1 card. Enter the rtrv-slk command.
  2. Delete the T1 interfaces associated with the card. Refer to the Database Administration - SS7 User's Guide for assistance.
  3. Re-enter the dlt-card command that generated this error message.
    Contact My Oracle Support if this error message appears again. See My Oracle Support (MOS).
