Go to primary content
Oracle® Communications EAGLE Commands Error Recovery Reference
Release 46.6
E93312 Revision 1
Go To Table Of Contents
Contents
Previous
Previous
Next
Next
E4643 Cmd Rej: Routing Number table is full
The maximum number of entries was reached in the Routing Number table. The Routing Number table cannot contain more than 10,000 entries.
Recovery
  1. Display the entries in the Routing Number table. Enter the rtrv-vflx-rn command.
  2. Delete routing numbers as necessary. Refer to the V-Flex User's Guide for assistance.
  3. Re-enter the ent-vflx-rn command that generated this error message.
    Contact My Oracle Support if this error message appears again. See My Oracle Support (MOS).
