Go to primary content
Oracle® Communications EAGLE Commands Error Recovery Reference
Release 46.6
E93312 Revision 1
Go To Table Of Contents
Contents
Previous
Previous
Next
Next
E3089 Cmd Rej: FTP Server password must be 1 - 15 characters in length
A password that is between 1 - 15 characters in length must be entered.
Recovery
  1. Re-enter the chg-ftp-serv or ent-ftp serv command.
    The password prompt appears again.
  2. After the prompt, enter the password for the FTP server, and press the Return key.
    The password must be at least 1 character and not more than 15 characters long.
    If an invalid password is entered (the Return key is pressed without entering a password, or more than 15 characters are entered), then the entire command must be entered again to cause the password prompt to appear again. The password is not displayed as it is entered.
